6th Gen ('00-'05): p0171 after cat clean out
Old Nov 6, 2014 | 08:15 AM
bossross's Avatar
Default p0171 after cat clean out
Cleaned out my cat then got a p0171 lean code
Have just been catching up on maintenance new belt , new filters still need to do pcv valve and fuel filter. Have a hole in maf screen and are planning to clean the maf. Any ideas.
Thanks MCF for leading me to cat problem.
got an 03 ss with 83000 miles
File Type: jpg
Old Nov 10, 2014 | 05:09 PM
bossross's Avatar
also the code actually came just before cleaned cat, I had to replace idle air control valve because of high idle.
Old Nov 10, 2014 | 05:24 PM
03SSLE's Avatar
P0171 can be triggered by a vacuum leak, a bad PCV valve, exhaust leak, sticky/stuck injector(s), dirty MAF sensor, low fuel pressure or a faulty O2 sensor.
Old Nov 10, 2014 | 06:42 PM
bossross's Avatar
if I didn't properly reattach the iac, might at be place to look for vacuum leak
have a new pcv valve but didn't get the o ring, do I need a new one for install?
Old Nov 10, 2014 | 07:04 PM
03SSLE's Avatar
Yes, without the o ring the pcv valve will create a vacuum leak.
Old Dec 21, 2014 | 11:31 AM
avendo's Avatar
how a dirty fuel filter for p0171...I keep getting it lately,was gonna change o2 under the hood is that the upstream one..
Old Dec 21, 2014 | 01:34 PM
owens91's Avatar
yes that one is the downsteam o2...and to the poster i would reccomend going down the things associated with that code and tackle the cheapest ones first
Old Dec 21, 2014 | 08:56 PM
avendo's Avatar
I ordered the upstream one tonite from rockauto..
Old Dec 22, 2014 | 05:24 PM
avendo's Avatar
I sprayed the egr valve around the gasket with brake clean and the engine reved up a little..
Old Dec 28, 2014 | 10:14 AM
avendo's Avatar
changed upstream o2 yesterday and got code today...
