p0113
Old Jan 16, 2007 | 04:19 PM
wiz kidd's Avatar
Default p0113
it was a couple days ago, but i'm pretty sure this was the problem i had with the check engine light being on...it seems that the one from my exhaust is gone...computer must have adjusted to it...but i put the cold air intake on a couple weeks ago now and now i'm getting this error code, i erased it with my obd2 but it came back again now....
anyone else have this problem?? is it something that will go away eventually when the computer recognizes it?? or is it a permanent thing??
Old Jan 16, 2007 | 05:18 PM
GrandPaDave's Avatar
Default RE: p0113
I don't have an answer to your question, but this link is for anyone who cares:
http://www.obdii.com/codes.html
Old Jan 16, 2007 | 05:22 PM
wiz kidd's Avatar
Default RE: p0113
hey, thanks for the site...i was lookin for something like that...usually i just google it and it tells me what the problem is and how to fix it..but i wasn't getting anything with this code...but here's what my code means
P0113 Intake Air Temperature Circuit High Input
Old Jan 16, 2007 | 07:57 PM
mickey's Avatar
Default RE: p0113
i dont ahve mine throwing that code. but let me know if you figure this out.
I know tha ti have also taken teh bat. out of my car and forced it to do a relearn
you may try this and see if it dont stop it also.
Old Jan 17, 2007 | 10:28 AM
wiz kidd's Avatar
Default RE: p0113
ok...so just disconect the cables and it should re-learn with the cold air on there??? or do you think this will just happen again?
i would never have thought that putting a cold air intake on would put the check engine light on....GGRRRRRR!!! lol
Old Jan 17, 2007 | 01:17 PM
mickey's Avatar
Default RE: p0113
yeah fro the most part.
take the cabels off the car and walk away for a hour or so and then re hook up and go from there.
this forces it to relearn how you drive and also will hopefully cause it to relearn the air flow for you.
Mine never caused a light or a code. so with luck this is the cure for ya.
