overheating
Old Mar 14, 2011 | 07:38 PM
jimp00's Avatar
Default overheating
Is this a common problem with mc,my new problem is the gauge goes up to about half and then goes back down.I put in a new thermostat,water pump,drained the system twice,tried purging it no antifreeze comes out.When should the fans go on,checking them out today.Thanks again for all the help
Old Mar 14, 2011 | 07:44 PM
Halfway on the gauge is the stock reading for the 195° thermostat
Fans kick on at 212°
Old Mar 14, 2011 | 07:49 PM
jimp00's Avatar
Thanks for that info is hot when I take off the radiator cap off also why would the gauge be going up and down
Old Mar 14, 2011 | 08:08 PM
Stop and go driving? Or all open air??
Old Mar 14, 2011 | 08:14 PM
jimp00's Avatar
Went for a drive 250 miles would that tell me
Old Mar 14, 2011 | 08:39 PM
Just was wondering if the temperature rose while stopped in traffic, then went down when moving because that would be 100% normal.
Old Mar 14, 2011 | 09:35 PM
jimp00's Avatar
seems to do that in both situations,any reason why it wouldnt purge all the air out of the system
Old Mar 15, 2011 | 07:31 AM
When you replaced the thermostat, you bled the air out completely correct?
You just open the thermostat bleed screw and wait for the car to get to normal operating temperature where the thermostat would open. Could take 10-15 minutes
Old Mar 15, 2011 | 02:09 PM
jimp00's Avatar
Did that to nothing coming out,is it suppose to put out a little anti freeze when the air is all out.
Old Mar 15, 2011 | 02:28 PM
Yes, once the antifreeze starts to come out is when you stop and tighten the bleeder back up.
