overheating
Is this a common problem with mc,my new problem is the gauge goes up to about half and then goes back down.I put in a new thermostat,water pump,drained the system twice,tried purging it no antifreeze comes out.When should the fans go on,checking them out today.Thanks again for all the help
When you replaced the thermostat, you bled the air out completely correct?
You just open the thermostat bleed screw and wait for the car to get to normal operating temperature where the thermostat would open. Could take 10-15 minutes
