Non working brake lights on a 98 Monte
Old Mar 12, 2009 | 07:42 AM
bitsy5085's Avatar
Default Non working brake lights on a 98 Monte
When I hit the brakes on my 98 Monte the light in the rear view window works, but the tailight brake lights do not work. I replaced the tailight bulbs and the brake lights did work for awhile. Now they don`t work again. Only the light in the rearview window works. The bulbs in the tailight assembly are new bulbs. Only installed them a week ago.Any suggestions? I thought maybe the part by the actual brake pedal might be the problem. It`s driving me crazy.....Bob
Old Mar 12, 2009 | 06:26 PM
wrenchead3's Avatar
Wont be the switch because the third eye ( back window light ) works. Grab a test light and start from the socket and start working backwards until you find the bad spot.
Old Mar 14, 2009 | 05:14 PM
bowtietech's Avatar
Turn signal switch is the most likely cause. I have replaced quite a few turn signal switches for this on 95-99 Monte Carlo's.
randbement
Jun 21, 2017 10:52 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
matrx10503
Nov 4, 2011 10:42 PM
thedude
Sep 1, 2006 10:26 PM
