No power in a 1977 Monte Carlo
Old Jan 20, 2011 | 02:41 PM
powerby50's Avatar
Default No power in a 1977 Monte Carlo
Hey guys, i just picked up a 1977 Monte Carlo that has been sitting for 15 years.... I replaced the battery however i get no power to anything in the car (no lights, no hazards, nothing).... I am getting 12.6 volts at the connected terminals ..... any ideas where the problem is?
Old Jan 20, 2011 | 05:53 PM
kazuya's Avatar
Hi there, try checking your main fuses and fusible links or wiring from the battery to the ignition switch as well as the ignition switch itself. Have you tried "jump start" with another car?
Old Jan 20, 2011 | 07:48 PM
powerby50's Avatar
problem solved....... terminals needed to be sanded down for a better connection
Skeletal Crow
Mar 30, 2011 10:04 AM
