6th Gen ('00-'05): No heat on passenger side
Old Nov 17, 2015 | 06:26 AM
Gene53's Avatar
Default No heat on passenger side
Good morning all. I am not getting any heat on the passenger side of my 2003 Monte. I slide the control up and down, and it does not make any difference. The driver's side works properly. Typically, would this be a fault of the control, or the baffle ??? Thanks in advance.
Old Nov 17, 2015 | 07:53 AM
This link may giver you a place to start
Click--> https://montecarloforum.com/forum/mo...=actuator+door
Old Nov 17, 2015 | 08:57 AM
Gene53's Avatar
Thanks. I'll start with the actuator. At least it's the one on the passenger side, so it is easy to get at.
Old Nov 23, 2015 | 08:09 AM
Gene53's Avatar
That solved to problem. Bought an AC Delco replacement from Rock Auto. Thanks for the help.
