no heat
and no has nothing to do with the security system the only problem you will have is untilyou plug everything back in you wont have turn signals.... but i have been driving around like that until i install my deck just because i dont want to pull everything off again
it is because your ignition switch is bad buy one for 30 bucks on ebay and install it directly behind where your keys goes in. It will shut down your heat ac fan and overhead display this mine shut down my cruise control as well. sometimes it will turn on sometimes it wont but after you put a new one in it hasnt not worked at all. and its cheap and easy to install yourself... just make sure to remember to turn your key to ON and then hit the switch on the cluster and the silver part will slide right out then reconnect the wires and your good to go
phillip9698
Apr 30, 2010 08:37 PM
