7th Gen ('06-'07): Negative Battery Terminal "Tightener"
Old Feb 19, 2018 | 03:47 PM
manseroti's Avatar
Default Negative Battery Terminal "Tightener"
I've managed to break the small "tightener" for my negative battery cable. A picture of what I'm trying to describe is below:
It's not the nut or bolt that I'm looking for, but rather the piece that sinches the terminal tight. I'm hoping I can just buy the small clip rather than having to replace the entire cable. I've searched online and can not find the replacement clip/tightener/fastener...whatever it is called.
Has anyone had any luck with a similar search?
Old Feb 19, 2018 | 07:45 PM
96z34man's Avatar
Aint gonna happen. And the aftermarket cables have completely different ends. Gird yourself to pay $150 for a piece of metal worth about a quarter.
Old Feb 20, 2018 | 07:59 AM
My negative busted the EXACT same way, been broke for over a year now. It still sits on the post snug enough that it stays on but I'm going to be buying a new cable here soon. I mean, maybe get yourself lucky at a salvage yard but at that point those are probably going to be as corroded as yours is. Those parts come as an assembly so you're going to have to buy the whole cable. And I would not cheap out on these - buy the OEM cable.
Old Feb 20, 2018 | 09:44 AM
Jeffs02rwdSS's Avatar
Not having one of the models so I can't look, but isn't there a way a person could solder a lug on the cable and use a different style clamp ?
