need some advice (cooling system and power steering)
Old Aug 2, 2009 | 06:32 AM
weizie's Avatar
Default need some advice (cooling system and power steering)
hey guys, i havent been on for a while because i have been working to pay off a mechanic bill. but my 2005 SCMCSS was int he shop for about 3 weeks, apparently the previous owner put a **** load of that radiator hole plugger and after me driving it for a year completly clogged the radiator, the thermostat, heater coils, and waterpump. now that everything was replaced the **** that cloged it in the first place is still in the engine and no matter how much we flush it the stuff is still there. Any one have any ideas on anything else i can do to get rid of this stuff?......and on a different note my car is making a high pitch whining sound when i turn, so i pretty sure its my power steering but i cant find the resuvare to check it any one know where it is on the 3.8l?
Old Aug 2, 2009 | 07:16 AM
..Hi Weizie, Hopefully one of our expert tech member's will have a solution/suggestion for you.
Check back on your thread ? Below are a few links to check out. Hope they help...Also your Power Steering
Reserviour should be on your power steering pump.
It's a black cap...Good Luck
Automotive Treatments Radiator Flush: Manufacturers a range of ...
Automotive Treatments comprehensive range of products are suitable for an ... Radiator Flush: A powerful radiator flush designed to clean and remove scale ...
www.automotivetreatments.com/automotive.../radiator-flush.htm - Cached - Similar
Questions about Radiator Flushing - Ask.com
Radiator Flush Find San Francisco Auto Shops, Mechanics & Auto Services. Auto. ... If required add a special flush agent to clean radiator, engine block, ...
www.ask.com/questions-about/Radiator-Flushing - Cached - Similar
Old Aug 2, 2009 | 01:22 PM
sonin66's Avatar
did you or they try any of that rad flush. i recently saw some at walmart
zyon555
Apr 21, 2020 05:09 AM
weizie
Jan 18, 2010 01:16 PM
sharon1175
Jan 21, 2009 01:26 AM
warrantykiller04
Jun 19, 2006 11:46 AM
