Need Help Fast!!! UGH
Old Apr 24, 2010 | 07:09 PM
Default Need Help Fast!!! UGH
ok so as of right now i have no fog lights at all, they will not turn on at all all fuses relays are good ive got SERVICE VEHICLE SOON light up on the message center, i was putting in hid fogs & they worked so i put the car away just came out to goto town turned them on & nothing idk whats wrong anyone else have a prob with putting in hids in the fogs???, the only thing i can think it could be is the switch but i was replaced when the car was rebuilt
so any and all help is appreciated
Old Apr 24, 2010 | 09:02 PM
04 dale jr supercharged's Avatar
well i have a 2004 and i was told u have to get a dif housing but u got them in got any pics if you have hids and it was working fine check your bas
Old Apr 24, 2010 | 09:27 PM
yeah they fit fine, but the problem is in the cars system somewhere but all the fuses and relays are good so idk what it is they were working than quit & regular bulbs wont even work
Old Apr 24, 2010 | 09:39 PM
nemesis's Avatar
2009 Monte Of The Year
play around with the ballast a bit unplug them and put them back in. make sure you have the connector plug in to the ballast the RIGHT side in. i done that at the track last year when taking off the driver's side head light. the passenger side work and driver side doesn't. all i did was turn the plug around and plug in and both light up.
Old Apr 24, 2010 | 09:49 PM
well i know its not in my hid system everything in that works fine its in the car itself, bc i put the stock bulbs back in & they dont work so idk
Old Apr 24, 2010 | 09:55 PM
nemesis's Avatar
when you plug in the connector did you push all the way in til the lock click? i'm just rambling on to give you idea lol.
Old Apr 24, 2010 | 10:00 PM
yup it was put in the same as the headlights & it worked than i went to leave & they wouldn't turn on the fog switch don't light up & ive got Service Vehicle Soon displayed on my msg center, so im lost
Old Apr 25, 2010 | 12:13 AM
nemesis's Avatar
might have to take to autozone and have them scan it, that's other option.
Old Apr 25, 2010 | 02:54 AM
u can take it to autozone but they have cheap scaner it wont tell u the problem did u check fuses and check or relay
Old Apr 25, 2010 | 12:15 PM
All the fuses were good, i scaned it myself with my scaner didnt say anything so i stareted to chase wires & there was a broken wire bout halfway threw the harness so i fixed it & it works now lol thanks for the help
