mystery symptoms
Old 04-24-2011 | 09:06 PM
jshladwig's Avatar
Default mystery symptoms
Okay i have a 95 mc z34 and when i start it, it dies a few times. Now when i drive those its like the fuel won't register/hesitates. The check engine light comes on then goes off. And after the hesitaion and i take my foot off the pedal its like the car us giving itself some gas!!! Sometimes the car will steal while I'm driving. Basically its the same symtoms of a bad tps. I put a new type and tested it plus my fuel pressure and volume us up to specs and i looked at it with a scope and it wasn't the strongest electrical pattern but ok. Can some please help me out!!!!
Old 04-24-2011 | 09:35 PM
Gunner's Avatar
My brother had the Lumina Z34 with the same exact problem, needless to say, 600 dollars later and a month in the shop, and they never could figure out what was going on with it. He eventually just sold the car and bought a newer model monte.
Old 04-24-2011 | 10:32 PM
jshladwig's Avatar
WOW!!! That's messed up. Well I'm going to put in a new fuel pump and ect and of that doesn't fix it than I'm doing the same!!!
Old 04-25-2011 | 06:46 AM
Sorry to read about your problem.
How many miles are on your Monte Carlo ?
Do you have any modification to your engine ?
Have you ever tried seafoam ? It helps clean 4-Sure...
Keep us updated & don't give up...
Post as many details of your problem as you can & this will help our expert tech members help.......GOOD LUCK
Old 04-25-2011 | 11:17 PM
jshladwig's Avatar
Default Update!!!!!
Ok i did a lot of testing today and came to find out that the honey comb in my cat is so bad its causing a major restriction which is causing my symptoms and the check engine light to come on/O2 sensor. Luckly i have a brand new cat and resonator but with school and work i just don't have the time!!
02montecarlo
10-11-2011 03:06 PM
LW57912
09-01-2010 10:26 AM
jhartley
13
05-22-2010 09:44 PM
skylark65
05-10-2010 10:07 PM
nitehawkjcb
04-13-2010 11:49 PM
Quick Reply: mystery symptoms
