Mystery Leak
Old Mar 17, 2011 | 05:10 PM
Default Mystery Leak
I don't have any of my books with me, left them at my parents' where I am heading this weekend, but I noticed a leak under my car that I can't place, nor can I tell what it is. Seems to be clear without a smell...
That circle in the middle of the picture is the culprit, anyone have an idea what I'm looking at? Before I check out my books and the car on jack stands.
For point of reference, that is my ZZP Downpipe in the photo and that is my Catalytic Converter.
Old Mar 17, 2011 | 05:54 PM
Montelicious's Avatar
So your belly button is leaking???? Ewwwww! LOL Ok, seriously, I will ask Ray to look at the pic when he gets home from his Irish dinner....
Old Mar 17, 2011 | 05:56 PM
mrl390's Avatar
Thats a drain plug for the floorboards incase they ever fill with water for some reason. I assume I am looking at the drivers side. I would pull back your carpet if possible and see if any water is standing, tho your carpet would probably be wet if there was.
I'm thinking it might be a drain plug for something, and it seems to be only water, but still. It's something I noticed and want the answer too lol
Old Mar 17, 2011 | 05:57 PM
LOL thanks Matt for confirming. I didn't notice my rug being any wet, I'll tear it apart this weekend I guess. UGH
Old Mar 17, 2011 | 06:05 PM
mrl390's Avatar
Are you sure its actually leaking out of there or is water just collecting on the floor pans and dripping from the plug? Those shouldnt leak water even if the floor boards were FULL of water. How much of a puddle are you getting underneath that spot?
Old Mar 17, 2011 | 06:13 PM
Water is definitely dripping from the plug, I couldn't tell you the amount but it was a pretty steady drip while I was taking the picture and touching the liquid to smell it.
Enzo354's Avatar
STILL SLOW
Can you pull out the plug?
Old Mar 17, 2011 | 06:30 PM
mrl390's Avatar
They are designed to be pushed up into the floor boards so you would have to have the carpet pulled up to pop it out.
Old Mar 18, 2011 | 12:39 PM
RickAKATed10's Avatar
Photobucket
Yikes, I hope this doesn't turn into a bad problem for you.
