More than one ebcm location?
Old Apr 8, 2018 | 04:51 PM
Bradford's Avatar
Default More than one ebcm location?
The ebcm is the module on the abs pump near the master cylinder correct? Or is that a different module? Im seeing a diagram showing it is under the dash near the bcm. Which Is it? I' so confused.
Old Apr 9, 2018 | 05:53 AM
Jeffs02rwdSS's Avatar
Not sure what year car you have, on my 2002 the bcm is located under dash on drivers side by fuse box. The PCM (engine computer) is located under the air filter assembly. I'm guessing you're looking at the abs computer located by the master. Couldn't confirm I already removed mine. Hopefully this helps you .
Old Apr 9, 2018 | 09:47 PM
Bradford's Avatar
Mine is a 2004. After looking through the service manual it appears I was correct and the ebcm is the module on the abs pump. I just got confused after seeing some diagrams posted showing it under the dash next to the bcm. That must be for a different year or something. I need to test the wiring harness to it because I am unable to communicate with it. I just wanted to make sure I was testing the connector at the right module and that there wasn't more than one brake module or something.
