monte trans fix
Old Oct 2, 2014 | 08:47 AM
2blackchevys's Avatar
Default monte trans fix
Hi its been a while and just want to pass alone some good info to anyone still having trans gremlins. Had some issues with tranny in my 2000 ss for the past year or so, between 80 and 108k miles, it has take off shutter, max line pressure, wine sound, and lately it wont go in overdrive after a long drive sometimes on the highway. All problems happen at different times. So i finally changed the fuid and filter as a last ditch effort to correct the issues only i used type F to refill, this is the same stuff i use in my hotrod nova and took care of 90% of the issues. Hope this helps some of you aswell.
Old Oct 2, 2014 | 04:29 PM
turbo monte's Avatar
i doubt it was the fluid that made a difference but by installing a new unclogged filter is probably what helped. this wont be a permanent solution for sure.
Old Oct 3, 2014 | 06:21 AM
You are right this isnt a permanent fix but will keep you going for a while, i used type f instead of the dextron 6 because f doesnt have any slipping modifiers and produces a firmer shift just like the b&m fuid and cheaper. Only cost $50 to try this.
Ronnie T. Vaughan Sr.
Nov 28, 2011 09:30 AM
1ATony
FWD Tech Guides '95-'07
Feb 1, 2011 01:23 PM
Ramairetransam
Mar 28, 2010 01:28 PM
juvaknight
Jan 7, 2010 12:14 PM
