4th Gen ('81-'88): Monte Carlo 1985 won't start
Having starting issues so it's cranking but not starting. So the belts are moving but nothing. Sprayed starter fluid and out gas in the carb still no start and sounds the same so not sure where to go from here. I checked I have power going to the distributor. But not sure I don't think it's a fuel thing I believe it's a fire thing but not sure. I changed wires and spark plugs. Not sure if rotor or distrubutor have anything to do with it. Any help would be perfect. Ohh signal lights work brake lights work that's it. One fusable link that goes to the lights I believe I have to replace but vehicle was still able to start before so not sure if the other one has anything to do with it starting or not? Other one with the test lead didn't have any power but not 100 percent sure.
Yeah I out a spark plug tester and not creating anything no spark. I put a light on the end with the ignition start light lights up still won't turn over. Or no fire. My radio doesn't work but my lights do. Before I use to turn the key and hear a buzzing noise then it would go off I don't hear that noise anymore. Not sure if anything is connected with that or not.
Rotor turns have a new hei cap but rotor turns has to be the cap or the wiring I guess. Cause with the old cap and new one it's doing the same thing.
No fire to plugs have a spark plug checker and getting nothing not sure hei is brand new but not rotor so I can see if those are cracked. Thought of changing out but I thought u had to start the car first to set it so decided not too
