monte A/C
Old Jun 1, 2008 | 08:39 PM
bigtire's Avatar
Default monte A/C
My 2003 Monte is leaking refrigerant from the air conditioning system. Have no idea where it is leaking out at , hope it isn,t evap. coil. Is this a common problem with these cars and if so, where is the most likely area to start checking for leaks?
Old Jun 3, 2008 | 07:08 PM
mickey's Avatar
Default RE: monte A/C
nope not normal on any car with A.C.
Go to autozone etc... and get a leak finder kit. and another can of 134A freon and the stuff to put it in (ge tthe kit it will explain how to do it if you dont already know)
but do the leak kit use the U.V. light and then it will le tyou know where it is leaking
