3rd Gen ('78-'80): monte base model
Old Jan 9, 2022 | 02:09 AM
BadBill66's Avatar
Default monte base model
I need help in finding the color code or number codefro the dash plug. I am doing my own dash rebuild.
Old Jan 9, 2022 | 05:50 AM
Hi, have you been to the below website? While this does not tell you where or how to find the color code you ask for it does list the colors by the year. And from that you should be able to know the color from the drop down menu as it seems they only have about 4 dash colors per year. Like, black, green, brown, purple etc. So this should get you the answer to your search.
dixierestorationdepot.com/Product/Browse.aspx?d=175&p=1
Old Jan 10, 2022 | 04:46 PM
BadBill66's Avatar
What I mainly looking for is the color code to the wiring of the gauges in the dash. I'm putting aftermarket gauges in and the PCB will not match up to the gauges that I'm using. There is a plug that plugs into the back of the dash do the ptcb. That is the wiring color code that I need. I already have the gages I want to use. I have pulled the PCB from the back of the dash because it was damaged.
miles137
May 10, 2017 12:38 PM
JoeNH3
Nov 13, 2011 09:10 PM
Gib DTD
Sep 15, 2009 12:25 PM
white74
Jul 20, 2008 08:06 PM
Mallet
Sep 6, 2006 06:07 PM
