MAP sensor
Old May 5, 2018 | 06:03 PM
Default MAP sensor
Are the map sensors from the NA and SC 3800s the same??
Old May 5, 2018 | 06:41 PM
No, they are different
Old May 6, 2018 | 06:55 AM
K thanks..
Old May 7, 2018 | 08:58 AM
The NA one only reads up to 1 bar of pressure, the boost ones read 2 so they know the boost the engine is pushing.
Old May 7, 2018 | 02:35 PM
Ok, if needed could I put the boosted MAP into a non boosted 3800?? This is highly unlikely but just in case I have to drive the backup btch..?
Old May 7, 2018 | 09:25 PM
No, they're not swappable like that. The output voltage has the same 0-5 volt range on both sensors. The 2 bar just has bigger jumps between each voltage point. So 14.7 psig will be nearly maxed at 5v on a 1 bar sensor, but a little below 2.5v on the 2 bar sensor. The pcm is tuned to know what value to expect for a given voltage, so just swapping them would probably freak out the pcm.
You could tune the NA engine to to work with the 2 bar, but it wouldn't make much sense. You can grab a used 1 bar from a junkyard for dirt cheap if you want a spare.
Old May 8, 2018 | 07:52 AM
Yea, ok so the problem was I was told 60 bucks from the guy at the junkyard.. He was a new guy there..
Went to talk to the normal guy I deal with there, and got it for 5 bucks..
Good info to know tho, thanks..
Old May 8, 2018 | 11:15 AM
That first guy was an idiot. Brand new retail is only like $45. The cheap aftermarket replacements go down under $20.
With all of the people that have done top swaps and such, you could probably get one for free from a local off one of the forums. I bet most get tossed in the trash as they're near valueless.
