Maintenance: I and II cycle?
Greetings all.
Am I to understand that my '07 MC LT's periodic maintenance needs are simply met by cycling through the "Maintenance I" and "Maintenance II" intervals until about 50K miles...when some additional services are needed on top of that? I'm about to hit 30K miles (a big interval for most makes, it seems), and I'm a little surprised that the manual indicates that not much more than a Maintenance II will be needed. I always thought of 30K as when moderate-level replacements/flushings/drains-and-fills are done. Is this not the case because so much on this car is rated for 100K-mile life? I don't want to neglect anything, but neither do I want to pay for things that aren't needed. -M |
:rolleyes:...Hi MotorHead, Treat your Monte with love and it will love you back 4-Sure...Abuse it, and it will abuse you : (
Yes, just follow the Maintenance schedule and you should have many happy miles in your AweSome Chevy Monte Carlo... Good Luck & EnJoy your Monte : ) GM Maintenance II Related Services & Repairs GM Maintenance Service GM Maintenance I GM Oil Life System (OLS) OVERVIEW *Note - This is a general guide to what is performed on your GM vehicle. Inspections and procedures will vary depending on your specific model GM recommends the Maintenance II service is performed when :
25,000 Miles/75,000 Miles/125,000 Miles
GM recommends more frequent changing of the automatic transaxle fluid and filter if the vehicle is mainly driven under one or more of these conditions:
About this Repair: Maintenance II Best Practices
