LS 03 problem,need HELP ~> Please
boca raton in west palm
lol thanks for the welcomes and heres a video of my car and what its doing
http://www.youtube.com/watch?v=XPTgMxw9aoA
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
Hey `Allen ~>WonderDuck, Super Vid Commentary on your Monte Problem...I hope one of our Super Tech Member's reads/see's your request 4 HELP....and can assist & give you some infor on your problem...
That was a decent vid 4 sure by your laptop....Check back on your thread to see what member can help...
p.s. how many miles on your Monte LS ?
I will do some research....Good Luck ~> Peace/Out
Click 2 watch vid of problem....Thanks
![](https://montecarloforum.com/forum/images/kirsch/buttons/viewpost.gif)
Check out the below links...It's your homework assignment 4 this eve : )~*
How do you reset the check engine light in a 2003 chevy monte carlo? ~>unhook a battery cable for about 3 minutes and re-hook.
Automatic Transmissions A Short Course on How They Work
Once the computer receives this information, it then sends signals to a solenoid pack inside the transmission. The solenoid pack contains several ...
www.familycar.com/transmission.htm - Cached - Similar
Automatic Transmission Solenoid - Ask.com
Top questions and answers about Automatic-Transmission-Solenoid. Find 21 questions and answers about ... Symptoms of a Bad Transmission Solenoid ...
www.ask.com/questions.../Automatic-Transmission-Solenoid - Cached - Similar
I'm thinking possibly the 1-2 shift solenoid or the EPC (pressure control) solenoid in the trans, I think the LS has the same 4t65e trans as the SS? If so it's common in those. Not too simple of a job though since the passenger side suspension has to come apart so you can access the trans near the front passenger wheel well. At least that's how I remember it coming apart. Some info on the 4t65e here: http://www.tripleedgeperformance.com...ssion_Info.php
Bonus answer - I believe the traction control and ABS lights are most likely a failed wheel speed sensor on one of the front wheels. I'd swap out both wheel bearing hub assemblies. See here for details: https://montecarloforum.com/forum/sh...ad.php?p=12379
The good news is these cars are well worth investing in. My '03 SS chassis has over 204k miles. I've done an L67 swap and a good amount of other repairs and it runs and handles great. Interior has held up far better than my '06 Charger that has less than 75k on it. If I splurge for new struts it will probably handle just like new again!
Keep us updated & let us know if you were able to solve
your problem `ok.
Explore the MCF & use our search engine for subjects of
interest, & if you can't find
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
Good Luck ~>4-Sure
Peace/Out
![Cool](https://montecarloforum.com/forum/images/smilies/cool.gif)
Additional Reading from the MCF ![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
bad cat.... symptoms? fixes? - Monte Carlo Forum - Monte Carlo ...
10 posts - 6 authors - Last post: May 9
bad cat.... symptoms? fixes? Headers, Intake, & Exhaust. ... Take it out. Best way to not have a cat clog up again ... 03 Impala / 07 GP GXP / 96 Monte - L67, whipple & more http://www.youtube.com/watch?v=tHCk1jBJqCs ...
www.montecarloforum.com/forum/showthread.php?t=20543 - Cached Catalytic Converter issues. - Monte Carlo Forum
New member from Minnesota: 2004 Chevrolet Monte Carlo Supercharged ...
2003 Monte Carlo Lack of Power - Monte Carlo Forum
03 Monte Carlo LS - PO720; PO1811; PO128; PO420
More results from montecarloforum.com »
2003 Chevy Monte Carlo help
Feb 28, 2009 ... 2003 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic 106000 miles ... it to a chevy dealer and they said it was the ttc solnoid and the cat, ... On 2001-2002 vehicles, a plugged orifice on the case side of the spacer plate. ... If the above symptoms are present proceed with the following steps. ...
www.2carpros.com/forum/viewtopic.php?p=500483 - Cached
