Low Power PLEASE Help
Ok a couple things to add here.....
o2 voltage is reading X1 mostly switching back a forth from .1 to .8 but does jump around a little.. Seems to wanna stay at .1 tho
X2 wants to stay about .4 -.5
AFR 14.7
MAF maxed out at about 200g/s
Getting a small amount of KR. For a split second I saw .8 then .2 then again .8 (This was at WOT at higher RPM) See tho, my timing advance WAS 18.5-19.6 at WOT previously. Now its what, 12?? So, its not pulling that amount because of knock.. WTF?
No vac leaks
Idk, when someone has a minute let me know if any of this info is of any use..
AFR 14.7
No vac leaks
Do you trust the sensor? The hard part is it contradicts the really low LTFTs.
AFR 14.7
Just throwing it out there - how about the electrical system overall, have you checked all the grounds engine grounds to make sure theyre good? I know it's a long shot, but ground issues could make sensors act wacky.
Intake temps are always low.. Right now its not going above 70..
Im gonna search around and redo some grounds..
Could the wiring going to the IAT sensor have anything to do with it?? I made it longer many months back just because the way I set up my intake, it was either extend the wire or redo the entire intake after it was all put together..
