Low Coolant Level Sensor / Idiot Light Issue
Old Jun 1, 2011 | 10:04 AM
Sparky-88's Avatar
Default Low Coolant Level Sensor / Idiot Light Issue
Hey everyone,
I recently replaced the coolant level sensor in my wife's '02 Monte. The 'Low Coolant Level' idiot light had been coming on but coolant level was fine. After replacing the sensor, all seemed normal at first. Then the idiot light started coming back on. It now comes on (with an accompanying 'ding ding ding') a couple minutes after the car starts running.
Is there a code that needs to be reset? I didn't think so, but now I'm not so sure.
I suppose it's possible that I got a faulty sensor. Any other thoughts on potential solution?
Thanks in advance for any help you can offer.
Old Jun 1, 2011 | 10:22 AM
Did you flush the coolant recently?? It could be gunking up and causing the misreading
Old Jun 1, 2011 | 11:10 AM
Sparky-88's Avatar
I replaced the radiator a few months ago. Should be no gunking-up issues.
Old Jun 1, 2011 | 11:29 AM
Since it's a sensor the only thing I could think of is to disconnect the battery for an hour and make the PCM pull up new readings for everything.
Old Jun 1, 2011 | 12:55 PM
Sparky-88's Avatar
Thanks, Chibi. It's worth a shot and doesn't cost anything. I'll try tonight.
Old Jun 1, 2011 | 08:22 PM
PUNK LIFE's Avatar
I'm having the same problem. I have replaced sensor, thermostat, entire coolant resevoir, flushed out dexcool and refilled w/Prestone yellow. Light still comes on after 20min of driving, never loses coolant or runs hot. I Dunno wth to do...
Old Jun 1, 2011 | 08:24 PM
PUNK LIFE's Avatar
oh yeah, I disconnected battery too
Old Jun 2, 2011 | 08:17 AM
Sparky-88's Avatar
Originally Posted by PUNK LIFE
I'm having the same problem. I have replaced sensor, thermostat, entire coolant resevoir, flushed out dexcool and refilled w/Prestone yellow. Light still comes on after 20min of driving, never loses coolant or runs hot. I Dunno wth to do... oh yeah, I disconnected battery too
Well crap... that doesn't bode well for me. The only thing I haven't done is replace the reservoir. The radiator / coolant / thermostat were replaced a few months ago; the coolant level sensor a few days ago. I disconnected the battery for a few hours last night, but I haven't run it since then. When my wife takes her out later today I'll find out if there is any change.
Old Jun 2, 2011 | 08:05 PM
hotrodmonte's Avatar
Check the wire harness. Unplug the sensor and look at the connector and check for corrosion in the connector. It will be easy to spot. It will be green.
Old Jun 3, 2011 | 10:19 PM
Sparky-88's Avatar
Thanks. Will do.
