Low beams not functioning
Old May 13, 2014 | 02:55 PM
Crusader SS's Avatar
Default Low beams not functioning
Good afternoon all. My Low beams have stopped functioning. DRL's, hi beams, dimmer switch, parking lights, fogs all working. I installed HID's a few months back and they have worked great up until yesterday. Any help would be appreciated. Thanks,
Old May 13, 2014 | 02:58 PM
dbaldwin's Avatar
Hey damien, first step is to install a standard bulb and see if they work. Let me know how that goes and I can give you the next trouble shooting steps
Old May 13, 2014 | 03:11 PM
Thanks David. I will try it out once home. Really appreciate it.
Old May 13, 2014 | 04:13 PM
Habbibie's Avatar
How about the fuse for low beams under the hood. Mine blew out a week ago and I had the same problem.
Old May 14, 2014 | 02:58 PM
Could not locate a fuse for the low beams. I did try an original bulb and nothing. Any suggestions would be appreciated. Thanks,
Old May 14, 2014 | 03:28 PM
dbaldwin's Avatar
Ok, so if original bulb doesn't work look for the headlight relay. It should be in the main fuse block under the hood.
Old May 14, 2014 | 04:14 PM
Habbibie's Avatar
It's a 50A square fuse that you can see from the top if it's blown or not. When I'm by the car ill snap a pic of it
Old May 14, 2014 | 04:39 PM
03SSLE's Avatar
Have you checked the fuses?
Underhood Upper fuse panel:
DRL/EXIT LTS
EXIT LTS
If you used a harness to tap power directly from the battery there is most likely an inline fuse in it also.
Old May 14, 2014 | 07:18 PM
Hiroska's Avatar
Yo fuse blown homie, my hids blew like 3 of mine lol
Old May 15, 2014 | 12:28 PM
Hey David, thanks for the help. I have located the headlight relay, but it is in the side dash drivers fuse panel under a second cover. Is this what I am looking for? Thanks again,
