Low beams not functioning
Good afternoon all. My Low beams have stopped functioning. DRL's, hi beams, dimmer switch, parking lights, fogs all working. I installed HID's a few months back and they have worked great up until yesterday. Any help would be appreciated. Thanks,
Thanks David. I will try it out once home. Really appreciate it.
I did try an original bulb and nothing. Any suggestions would be appreciated. Thanks,
Have you checked the fuses?
Underhood Upper fuse panel:
DRL/EXIT LTS
EXIT LTS
If you used a harness to tap power directly from the battery there is most likely an inline fuse in it also.
DRL/EXIT LTS
EXIT LTS
Hey David, thanks for the help. I have located the headlight relay, but it is in the side dash drivers fuse panel under a second cover. Is this what I am looking for? Thanks again,
