the lights are on but the ignition isn't there...
Old Nov 7, 2010 | 01:53 AM
Ninjaraku's Avatar
Default the lights are on but the ignition isn't there...
when i turn the key it just turns all the way forward as it would first turning over the engine, like the switch to engage the starter isn't catching, key does not return to normal on position, but all dash lights come on, bad switch or bad cylinder?
Also, how do i take the column off that's around the key/turn signal housing? i got the little plate off by the turn signal but that's it, and i don't see any screws... part store said $55 for the switch or $35 for the cylinder with key.
1997 LS Monte Carlo v6 dual overhead cam.
with key turned on and if im lucky it's sitting just right, when i jump the starter the car stays on, thing is no telling if its going to shut off if i hit a bump down the road then its back to trying to get the cylinder to sit just right to keep the car on. again if i can get info on taking the column apart i could figure it out =p. Any/all positive tips are appreciated ^^
Old Nov 7, 2010 | 08:29 AM
locknload's Avatar
Check the ignition fuse in the under hood fuse panels. On the 04's the ignition fuse is a 60 amp, that is in the lower panel, it is the one on the lower left.
Old Nov 9, 2010 | 02:17 AM
Ninjaraku's Avatar
fuse is fine, its either the key cylinder or the switch in the steering column, its a 97, anyone know how to get the column apart? i don't see any bolts/screws...
iMuf
Mar 12, 2020 06:56 AM
rjmfa
Dec 22, 2012 12:17 AM
drjesus616
Aug 30, 2010 11:17 AM
biggriggs
Jun 7, 2009 06:29 PM
ironmanxjr
Jul 28, 2007 07:27 PM
