ISS Self Fix??
Old 09-07-2006 | 01:01 AM
White05LT's Avatar
Default ISS Self Fix??
Has anyone found out how to repair the ISS by yourself? Whats needed? Walkthroughs? Just wanted to know if anyones attempted it yet.
Old 09-07-2006 | 05:04 PM
SoCalSS's Avatar
Default RE: ISS Self Fix??
Refresh my memory. ISS is... the Security System right? What exactly is wrong with it?
Old 09-07-2006 | 08:39 PM
InTheIROC's Avatar
ISS= Intermediate Steering Shaft... it's the shaft between the rack & pinion and the steering column.
I did mine with the grease kit GM sells for it for $8 my cost (like $12 normally, I believe) and under an hour of my time.
Old 09-07-2006 | 08:53 PM
DRA2000SS's Avatar
with the iss needing to be greased can you also feel it when braking in the steering wheel cause if so I have the same problem.
Old 09-07-2006 | 09:30 PM
InTheIROC's Avatar
I sometimes felt it when braking but mostly felt it when turning. I put it up in the air and checked the front suspension and everything was good. So I did some research and found out about the common ISS problem. Bought the grease kit, greased it up and it's been fine since.
Old 09-07-2006 | 10:41 PM
GrandPaDave's Avatar
I get an occasional thud sound when I am braking and slowly turning. Just another thing to tell the dealer.
Dave V.
Old 09-23-2006 | 10:42 AM
RocknSS04's Avatar
I had mine replaced for me in my '01 SS. They are ALL crap from what I'm told, and hard to find a new one. Good luck on the fix, but if fixed early enough, it should work. I'm told that the manufacturer used the wrong grease when they were built. My 2 Impalas were both re-greased. The splines in this require too tight of a tolerance to feel right. Just a crappy design.
Old 09-23-2006 | 11:06 AM
montejass's Avatar
ORIGINAL: RocknSS04
And of cource GM won't admit this...... I had mine replaced around 25k, and was told at the time the entire truck line had the same problem..
So what happens to the ISS over time if you don't re-grease it?
BTW: That RocknSS ID looks familiar.... 2KMC?
Old 09-23-2006 | 11:49 AM
fever42's Avatar
TRY THIS SITE, WWW.COLINKRAFT.COM/SHAFT.PHP, ALSO WORKING ON A SHAFT PLUG AND GREASE FITTING FOR MY MONTE, WILL KEEP POSTED WHEN WORKING WITH INSTRUCTIONS
NO LONGER GOING TO HAVE TO REMOVE TO LUB, ALSO BETTER LUBRICATE(MARINE GRADE)
BEING I AM A MARINE ENGINEER
[IMG]local://upfiles/99/B792E5F787264C9A9DE8BAD9CD0B0A72.jpg[/IMG]
Old 09-24-2006 | 12:14 AM
White05LT's Avatar
Great write up! So you simply leave the shaft uncorked? Also, do you use the entire content of the grease injection? Also any higher grade grease that we should consider?
