7th Gen ('06-'07): inner tie rods
Old Mar 27, 2018 | 05:21 AM
monte0722's Avatar
Default inner tie rods
Hey I could use a little help Just bought a new front end kit, was having my mec. Install and he tells me the inner tie rods are the wrong ones say there are 2 types and mine were wrong so my ? is are there 2 different types?
Old Mar 27, 2018 | 08:24 AM
Jeffs02rwdSS's Avatar
Did a quick check online for you and only found 1 option inner tie rods for your car. I did notice there are 2 outer tie rods depending if you have soft ride suspension (FE1), ride and handling suspension (FE2) is part # ES3469 and for heavy duty suspension part #ES3463 . By the way these are Dura last part numbers from auto zone. Sorry I couldn't find the code for heavy duty. these codes are usually in the trunk on spare tire cover or in the glove box Good luck
