id like to have my door open w/ interior dome light OFF, ..... that possible?
whats up mcf! long time no holler. i hope everyones been alright.
i sell several products from out of my 2003 monte carlo ss day and night but it bugs me how during the night time while my door is open, my clients can see inside my vehicle (thanks to the super bright dome light). i have low percentage tint but at night time that dome light cancels that tint out quick! is it possible to have the door open with the interior dome light off. maybe a switch or something that can be turned on / off. of course i dont wanna disconnect the batterybecause sometimesi may leave my door open with the radio playing (so battery needs to be on of course). if theres any quick fixes or recommendation to achieve this task i certainly do appreciate it. thanks for your time guys! p.s. , i know about the emergency brake / headlight trick but this wont do anygood as it is the inside that needs to remain dark |
RE: id like to have my door open w/ interior dome light OFF, ..... that possible?
take the bulb out of the dome light...that will solve ur prob, but wont mess something up in case u sell the car and the other person wants the dome light to work.
Hi `Jay, Member bensminger `Brian posted the easy way to solve your problem, but I also think you could wire in a three way switch. 1. `off 2. On when door is opened. 3. On only when you turn it on. I would check your local auto parts store, or junk yard for a switch. Look forward to your future posts. Good Luck |
thanks guys ....... both great ideas that i never actually thought of! i certainly do appreciate the input and will post back with what i did later on today
what is the fuse wired up to also? if the fuse only does those lights, pull the fuse!
Originally Posted by vita
(Post 97640)
I did just that and will save the light bulb if I ever want to drive around at night with my dome light on!! That is a weird feature for sure. It was easy to take a small screwdriver and pop the cover. Wear fairly thick gloves because the light gets hot very quickly. I used the screwdriver to pop the light out, too. If I really need to see in the car, will just use a flashlight :)
| All times are GMT -5. The time now is 01:09 AM. |
