HVAC issue on 98 Z24
Old Jun 15, 2011 | 03:20 PM
DarkSS's Avatar
Default HVAC issue on 98 Z34
Last winter I slid into a car at work and cracked up the passenger side front of my Monte. After that the HVAC control for where the heat/ air comes out (defrost/panel/floor) stopped working. It now comes out mostly from the defrost and some on the floor no matter where the switch is. Could there be a vacuum canister that was broke in the accident? Any ideas? I'm trying to get my A/C all straightened out before it gets really hot. Thanks in advance.
Old Jun 17, 2011 | 01:51 AM
DarkSS's Avatar
So nobody has an idea??
Old Jun 17, 2011 | 06:18 AM
mrl390's Avatar
Your vacuum canister is on the drivers side but its still possible you broke a vacuum line or something from the force of the crash.
Old Jun 17, 2011 | 08:14 AM
KJRich's Avatar
It is very possible the impact did something. For example affter I hit a bridge and destroyed the fender on my '01 Tracker, my radio and dome lights stopped working. I ended up having to run a new 12 volt wire to the memory line on my radio. It was not a fuse or fuses, I checked multiple times.
mickey
FWD Tech Guides '95-'07
41
May 15, 2011 10:30 PM
augi
Nov 28, 2010 09:31 PM
cqdqd2
Jul 23, 2008 08:18 PM
desighitter
May 30, 2006 11:12 AM
