HUGE ISSUE, Passenger Side Water Leak
https://cimg7.ibsrv.net/gimg/monteca...46b4e9034e.jpg
Passenger leak in '00 Monte Carlo, even after GM Cowl fix! I have a huge issue guys, it leaks on my passenger side after big storms like this and I already installed that plastic piece GM made to drain the water but water still seeps in! :nono:What's the issue?? Any help would be greatly appreciated. Thnx |
I would check a couple of things. Make sure that the drain in the cowl is not clogged up with dirt/leaves. Have you heard sloshing after a heavy rain from the door - the drain holes will clog up with dirt/etc. I stick a toothpick in and the door will drain for 5 minutes sometimes.Make sure your door seal is clean and not damaged. As high as the water is, I would suspect the cowl drain, I believe it comes out just below the lower hinge. Also, check your headliner, if it is damp you could have a leak at the top of the windshield (actually been there, done that). Best thing to do is get in the car and have someone spray water at selected areas, or go through a car wash and watch for a trickle. Good luck.
https://cimg0.ibsrv.net/gimg/monteca...8a8be0fb27.jpg |
Already went through a car wash, trickled down in the same spot a bit, no water in the door when I shook it..idk what it could be. But, some of the panel clips on my passenger door is broken off so the door is loose..could it he seeping through there pass the water seal inside the door?
If the car is equipped with a sun roof, also make sure the sun roof drains are not clogged. I have yet to have that issue with my Monte, but I did have almost the same looking leak in my Grand Am and that is what caused it.
(Post 718371)
If I recall, there are 4 total sunroof drains. The two in the front I believe run down the a-pillar, and I believe they exit around the conduit for the door wiring in the door jam. You could run some water over the sun roof (just a cup, something small) and have someone spot if it exits a drain.
(Post 718383)
These are from a 2000 I saw in the wrecking yard yesterday. (not sure why this didn't post with the photos.)
Originally Posted by Glen01SS
(Post 718586)
https://cimg8.ibsrv.net/gimg/monteca...36a4553157.jpg
driver side https://cimg2.ibsrv.net/gimg/monteca...670ecc046d.jpg pass side https://cimg6.ibsrv.net/gimg/monteca...53edf931f2.jpg motor & wiring |
