how to open the door .... HOW TO DEMONTE
I M FRENCH EXCUSE THE WORDS . HELP ME
I WANT TO OPEN THE DOOR TO REPARE THE MECANISME ELECTRICAL FERMETURE KEY:confused: I SEE 4 VIS AND AND I DONT HAVE ANY PLANS TO GO INSIDE THE DOOR AND REPARE THE ELECTRICAL COMMAND KEY IT FOR SEE THE DOOR LEFT PLEASE IF YOU HAVE ANY PLANS IT IS A MONTE CARLO 1997 |
I'm sorry man, i dont understand what you are tryin to fix. Are you trying to remove the door panel? if so which switch are you trying to repair?
Welcome to the Forum! I was in France for a short visit last year, and I certainly felt out of place not being able to speak or understand the language.
However, I am having difficulty understanding your question. Is your remote keyless entry not functioning? Please show us the video, it might help us understand. |
Originally Posted by Cully77
(Post 129007)
He's asking how to repair the auto lock mechanism. He sees 4 screws but doesn't want to go inside the door (est-ce que j'ai fait ta demande correctement?) or wants to know how to repair the mechanism.
yes , oui c est exactement cela , exactly i dont no how to go inside the door when i have take out the 4 screws and did there s some clips or attacheements
merci beucoup pour cette traduction. |
you CAREFULLY pry the bottom of the door apart (there are plastic clips holding it on) and then LIFT on the door panel because there are metal clips on the top holding it on, and it should pop right off
Christophe: est-ce que tu comprends la note de Chibiblacksheep? Si non, envoie moi un PM (message personnel) et je peux essayer d'expliquer.
