How do you reset change oil light
Old Apr 18, 2013 | 11:01 AM
killerBee's Avatar
Default How do you reset change oil light
How do you reset change oil light in 03 monte carlo ss. I tryed Turning the key to the on position (do not start it) and press the gas pedal to the floor quickly 3 times. Didnt work.
Old Apr 18, 2013 | 11:21 AM
Hello here is a link on the forum about this. It's not just pushing the pedal 3 times, you need to have a second between pushes and the last one hold it down for 3 to 4 seconds. Then turn the key off and then start your car. This is the method I use and it works for me. Let us know how things went...
https://montecarloforum.com/forum/si...y-radio-10265/
Old Apr 18, 2013 | 11:48 AM
Harlan2012's Avatar
Yup the method above works perfectly its how i reset my change oil light also.
Old Apr 18, 2013 | 04:44 PM
killerBee's Avatar
Thanks. Worked Great
Old Apr 19, 2013 | 12:00 PM
killerBee's Avatar
I thought it worked but it didnt
Old Apr 19, 2013 | 01:30 PM
Just pump it 3 times with the key on...
Slowly..
Then start the car...
Old Apr 19, 2013 | 06:19 PM
03SSLE's Avatar
I've run into a couple of stubborn oil change lights on GM vehicles before. If the light doesn't reset the first time repeat the process a second time. Make sure you are pressing the pedal completely to the floor then allowing it to return to resting position before pressing it down again. Key ON engine OFF. If your factory chimes are functional you will hear them through the front driver side speaker indicating the reset was a success. After the final press of the pedal turn the key OFF and wait 10 seconds before starting the vehicle.
Old Apr 20, 2013 | 12:14 PM
GoodZwell's Avatar
Done this yesterday. Called the GM dealership the they told me how to do this on my 2002 Monte.
without starting your car turn the Key to the second position. Make sure your radio it turned off and your fan. Then on your radio hold in the display button on the left hand side of the radio. it's also the tuning button for radio stations. Hold it in for a few seconds until the display says "Settings". Then you toggle the search buttons to what ever you want to reset. Oil reset is there along with other stuff you can do. The on the present buttons "1 and 2" toggle that to the reset then press the tuning button to finish/done. Your chime should go off telling you that you have reset what ever one you were on. Hope this helps, head is a little foggy this morning. :0)
Old Apr 20, 2013 | 10:33 PM
Do you still have your factory radio or not? I assumed it was gone considering you were doing the gas pedal method...
Old Apr 21, 2013 | 10:37 AM
killerBee's Avatar
I got the factory factory radio
