How do i remove the dash bezel?
Old Jan 14, 2012 | 09:58 AM
fldiver23's Avatar
Default How do i remove the dash bezel?
Unfortunitaly it has cracked, the front part of the dash which acts as a bezel around the guages. to the left it covers your headlights and interior lights controls including a vent then on. to the right it has holes for the hvac controlls, vents and it continues under the radio. it is basically worthless.i found one at the junk yard but i dont know how to take it off. i broke one and the JY allready trying to figure it out my self
these are just shots of what im talking about on someone elses car
http://www.cardomain.com/ride/473859...e-5#4738590002
http://memimage.cardomain.com/ride_i...0047_large.jpg
Old Jan 14, 2012 | 10:37 AM
jakefluker's Avatar
Sorry to hear about your frustration,I believe clip inserts holds bezel together you just have to find where they are.Use a flat head screw driver to seperate bezel from foundation to find where clip inserts are but becareful not to use to much pressure which will cause chips,breakage etc.Or if hands strong enough pull bezel from dash and you will access to clip inserts.check for any screws that may be holding bezel together also
Jaymoung
Mar 31, 2015 10:20 PM
JamesB
Oct 2, 2012 11:45 AM
bracy67
Jun 15, 2010 08:48 AM
Squeegee
Apr 29, 2009 01:40 PM
