7th Gen ('06-'07): How to change rear spark plugs?
Old Apr 5, 2014 | 06:31 AM
nycmonte's Avatar
Default How to change rear spark plugs?
I am going to be changing my spark plugs on my 2006 LT 3500. i have read to access rear plugs you should remove front dog bone motor mounts and tilt engine forward. Does the motor need to be supported when doing this? Does the motor fall back into place when done? Any other helpful tips would be appreciated.
Old Apr 5, 2014 | 06:46 AM
What I did was to remove rear coil pack and valve cover
They weren't too bad to get to then. While your back there good idea to replace wires too also I got a new valve cover gasket to be safe some guys reuse em but they are cheap so why not?
I didn't mess with tilting the engine it won't buy you that much more room like a 6 banger would
Oh ya a universal swivel socket joint is a must
silver1
15
Sep 17, 2016 05:15 PM
golfstud2k4
Jan 6, 2007 04:24 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
2000_BLACK_SS
Sep 23, 2006 10:11 PM
bk4256
Mar 28, 2005 06:37 PM
