7th Gen ('06-'07): "Hot" Engine
Old Feb 24, 2018 | 11:56 PM
96z34man's Avatar
Default "Hot" Engine
So, my car starts now, but when it starts (and the engine is cold), I get the DIC message, 'ENGINE HOT A/C OFF."
The connector for the coolant temperature sensor did get broken when I replaced the the plug on cylinder 1, but when I check it, the sensor is in place.
Any ideas?
Old Feb 25, 2018 | 07:19 AM
If the coolant is fine, and you know the coolant temp sensor is fine, the 3rd common culprit for that message is the thermostat.
