horn on '06-'07
Old Oct 1, 2009 | 01:29 PM
myfirstbowtie's Avatar
Default horn on '06-'07
Does anyone know anything about the horn on the '06-'07 Montes? Are there one or two horns, and where are they located? I tried looking under that plastic cover between the grille and radiator, but I couldn't see them.
My horn doesn't sound quite the same as it did when I bought the car. It doesn't sound as strong. I'm thinking if there are two, maybe one of them isn't working.
Old Oct 1, 2009 | 01:36 PM
RickAKATed10's Avatar
Photobucket
Hm... Sorry I can't help, I hope you find your answer. Do you still have your warranty? If so take it to the stealer.
Old Oct 1, 2009 | 01:38 PM
The Popcorn King's Avatar
know mine has 2 horns. They are between the grill and rad. But mine is a 5th Gen so it may be different.
Old Oct 1, 2009 | 02:46 PM
The bumper-to-bumper warranty has expired. Only the powertrain warranty (5 yrs/100,000 miles) remains.
Old Oct 1, 2009 | 10:11 PM
God_Bot's Avatar
Two horns, behind/under the passenger side headlight. They should both be attached to a bracket.
Old Oct 2, 2009 | 09:19 AM
Thanks, Garrett. I'll check that out when I get a chance.
Old Oct 2, 2009 | 10:58 AM
God_Bot's Avatar
Yep, I remembered seeing them somewhere so I pulled out my Haynes Manual and that's what it said. Let us know if you find out anything
Old Oct 2, 2009 | 10:11 PM
slinkeey's Avatar
You are right.. Two horns behind the passenger side light.
Old Oct 5, 2009 | 10:40 PM
That's exactly where they are, right behind the passenger side headlight. Seems like kind of a strange place to put them, but whatever! Of course, the one that isn't working had to be the bottom one, the one that's harder to get at.
Taking out the right side headlight is also a good way to see how much fluid you've got in your windshield washer reservoir, or to change the bulb in your fog light if you need to.
jeffrae
Feb 20, 2017 10:02 PM
mitch520
Jan 22, 2009 11:16 AM
mc65
Apr 19, 2008 03:27 PM
odessadude
Oct 7, 2007 08:44 PM
steptoe
Jan 27, 2007 10:36 AM
