Help with transmission please !
Old Apr 13, 2015 | 04:02 PM
Baby Jesus Swag's Avatar
Default Help with transmission please !
So I have another post below about my 2005 monte carlo ls 3.4 l having jerky shifting. It doesn't always do it. Which is very weird to me. Everytime I need to show someone it shifts just fine. But clunks hard a lot of the time. Im not afraid of doing work myself as I love a challenge. If it's the solenoids in the tranny. What ones should I change ? I may try that first because I refuse to get a shop to do it for 800-1500 dollars when it would cost me only like $100 for the solenoids. If you guys dont think its the solenoids. What else could I try ? The tranny fluid is okay. I tried some tranny system cleaner. I tried fuel injector cleaner. Nothing has helped. The shop i took it to did tell me the motor or tranny mounts are pretty bad. Which could explain a clunk when I first take off. But not between gears.
Old Apr 13, 2015 | 04:07 PM
ohara's Avatar
The solenoids need to be replaced. They build up pressure in the lines which enables them to shift and when they stick the pressure builds up higher than normal which is what is causing them to "slam" into gear. The problem is not a consistent one, it comes and goes, like I said I got over 100 000 kms on mine before it finally failed on me, and some days it would do it and some days it wouldn't. I personally would replace them, cause if your in there anyways, you may as well do them all.
The tranny mounts, you may as well also change while you have the car up and everything apart, although I think you only need to take the side cover off to get to the solenoids, but still if your elbow deep in the job, you may as well do it all. ZZp has new poly mounts that are supposed to be great, and fairly inexpensive
Old Apr 13, 2015 | 08:45 PM
Sweet ! Now, what solenoids are in the side cover ? The PCS and the 2 shifter solenoids ? Are there any others i should just replace that could be the cause ? Or are those it. thanks for the response on both posts.
Old Apr 13, 2015 | 10:08 PM
ohara's Avatar
Here is a link to a kit on ebay that is for you tranny, it is $75 plus shipping
4T65E Transmission Solenoid Kit Set Package TCC Shift EPC 2003 Up New Free SHIP | eBay
and here is a link to a transmission master overhaul kit on zzp for $99 plus shipping, it will give you all gaskets and o rings you may need, you probably won't need all that it has, but pending how far you in to the tranny, you may as well replace as much as possible
TRANSTAR - 4T65E Master Overhaul Kit #
I think my other answers on your first post had links to youtube video's that will show you exactly what to do.
Old Apr 14, 2015 | 07:10 AM
Sweet thanks a lot. I just don't want to mess it up either. Dropping the rack and what not just seems to be asking for me to mess it up.
Jethro
Sep 15, 2013 09:24 PM
owens91
22
May 23, 2013 04:17 PM
superrod29
May 30, 2012 08:33 PM
Emnasty600
22
Oct 11, 2011 03:50 PM
reaper18769
Aug 3, 2010 10:52 AM
