HELP!!!! rear wheel bearing replacment...
Old Jan 22, 2011 | 11:20 PM
05_monte's Avatar
Exclamation HELP!!!! rear wheel bearing replacment...
I need some help does anyone know how to replace you rear wheel bearing hub assembly on a 05 monte. Its cold out and i already have the wheel, caliper, rotor, the four hub bolts off, sensor disconnected, and i know i have to disconnect the e-brake cable and the 2 retainer screws to dissassemble the backing plate. My question is does the hub assembly and e-brake assembly just pull out now? I dont want to be prying on it if im not supposed to.
Old Jan 22, 2011 | 11:24 PM
do you have ABS?
Old Jan 22, 2011 | 11:29 PM
05_monte's Avatar
yes i already disconnected my sensor
Old Jan 22, 2011 | 11:38 PM
maybe this will help? there is also a how to video!
http://www.1aauto.com/1A/wheel-beari...HR00036/316406
Old Jan 22, 2011 | 11:50 PM
05_monte's Avatar
No it doesnt the how to is for a front wheel and the video is just for customer satisfaction, but thank you anything helps
Old Apr 3, 2013 | 04:24 PM
1984SS2002's Avatar
hey Bud,you ever get that hub changed? im looking at the same job and need a few pointers on what to do and not do.
Old Apr 3, 2013 | 04:51 PM
03SSLE's Avatar
This thread is a couple years old, so I don't know if you'll get a response from the OP or not. To answer your question, you need to remove the caliper, rotor, parking brake cable, ABS sensor connector (if equipped) and the 4 retaining bolts. The hub should pull off, but some require a little persuasion to pop off.
Radagast the White
Aug 17, 2014 10:52 AM
valvefloatss
Oct 2, 2009 06:15 AM
Someairforceguy
Dec 31, 2008 04:39 PM
Someairforceguy
Dec 26, 2008 08:05 PM
