Help>Help >Service Traction Control Soon lights up?
Old Aug 5, 2013 | 11:34 PM
seen03's Avatar
sometimes the wires themselves corrode inside the wire loom as well. Also, the suffering feeling when u got the brakes is probably the ABS kicking in. That's usually a side effect of the bad wire or hub.
Ive diag. n repaired this exact same scenario on multiple gm vehicles...Rendezvous', any W body, ect
Old Aug 6, 2013 | 07:48 AM
VictoryRedSled's Avatar
had this same problem and when i looked, the wire connecting my right front Wheel speed sensor had completely snapped in half. So i had that replaced and it still did it, just less frequently. Then a member here suggested i clean my throttle body, since it is connected to a lot of the traction control system. I was skeptical at first, but I ended up cleaning it out when i had to replace a MAF sensor and i havent had that problem in about 6 months.
Old Aug 6, 2013 | 09:52 AM
ecosta221's Avatar
well today i was driving it to my garage to see if i could change the shocks and the hub on saturday and it didnt set the lights off at all. i still thibk somethings wrong with the hub tho so im changing it anyways.
Old Aug 6, 2013 | 09:57 AM
ecosta221's Avatar
if it does come back on and the hub doesmt solve the problem then ill try cleaning the throttle body but im leaning torwards the hub especially with this brake pedal feel
Old Aug 6, 2013 | 10:06 AM
ecosta221's Avatar
So far it didnt come back yet. it may have been dirt since i found out the previous owner changed the front hubs before he sold it. maybe ill get lucky and that cleaner fixed it. if not im changing the hub and if that doesnt fix it then im changing the entire harness to it
Old Aug 6, 2013 | 11:35 AM
ecosta221's Avatar
Alright well the spray didnt do anything and the message came back so on saturday im changing both the wheel hub and the wire harness to it as well. Ill post an update when its finished
Old Aug 6, 2013 | 02:33 PM
seen03's Avatar
...u could check the wire harnesses going to the guns as well.
Old Aug 6, 2013 | 08:29 PM
ecosta221's Avatar
Yea im just going to replace the hub and the harness along with it. Why have to take it off twice when im alreadyvthere right? Im doing it all on saturday so im hoping that solves the problem.
Old Aug 7, 2013 | 10:10 PM
ecosta221's Avatar
Alright so i have 1 more question about these sensors. Can they mess around with the transmission as well? Like ill be driving at about 40mph and the rpms will be at like 2k and then if i put my foot down itll jump to about 2 1/4 rpms the back to 2k and if i put my foot further down it downshifts by 2 gears and jumps to 3500 revs. Ive never noticed my car do that before this abs stuff happened. Can this be caused by my abs sensor being screwed up or am i just being paranoid and this is normal?
mwmarshall
May 14, 2022 02:43 AM
blackmonte781
May 6, 2017 11:41 PM
esquire2021
Mar 15, 2015 09:12 AM
Chris s
Jan 27, 2013 04:30 PM
black04monteSS
Apr 18, 2008 07:34 PM
