6th Gen ('00-'05): Help find water leak
Old Oct 29, 2015 | 03:20 PM
GTHSS's Avatar
Default Help find water leak
My 2001 SS is loosing coolant and I can't find where. The skid pan will be holding coolant, the water pump doesn't appear to be leaking. If its a intake gasket where are the normal places to check?
Old Oct 29, 2015 | 03:28 PM
coolhand's Avatar
My guess would be the coolant elbows on the belt tensioner.
Old Oct 29, 2015 | 04:35 PM
GTHSS's Avatar
A closer shows you are right about leaking at the elbows. Now i have to figure out the easiest way to replace them.
Old Oct 29, 2015 | 04:55 PM
plumbob's Avatar
Would have been my suggestion as well. Be sure to replace them with aftermarket aluminum ones made by Dorman. You can pick them up at any of the large chain auto part stores for around $12.
To replace, remove the coolant reservoir, serpentine belt, belt tensioner, alternator and it's bracket.
Old Oct 29, 2015 | 05:26 PM
coolhand's Avatar
If you still have the factory plastic ones, make sure you get the Dorman aluminum replacements and some Permatex. You'll never have to replace them after that.
Old Oct 30, 2015 | 03:41 AM
GTHSS's Avatar
Thanks guys. I have the metal ones going out to the heater hoses but still have the plastic 90 on the other side. The plastic 90 is the one that's leaking.
Old Oct 31, 2015 | 08:54 AM
plumbob's Avatar
Since the aluminum ones come in a two pack for $12 and you have to take all the same stuff off to get just one out you should replace both. I think I understand you right, There are two 90o's, one is hard to see w/o taking the tensioner off.
Old Nov 1, 2015 | 04:11 AM
GTHSS's Avatar
Thanks for the info!
Old Nov 1, 2015 | 10:25 AM
GTHSS's Avatar
Default drain plug
Is the radiator drain plug hard to find or non existent on the '01 SS?
Old Nov 1, 2015 | 10:56 AM
plumbob's Avatar
The petcock is at the lower, driver side. The air deflector hides it. Best to remove the deflector.
