Help
Old Feb 4, 2018 | 02:29 PM
cstar65's Avatar
Default Help
So I am having this problem with my new to me 2000 Pace car edition. Its got the 3.8 engine. The symptoms I have narrowed down: I get a rapid thumping type of feeling/sound when accelerating and steering to the right. Like when accelerating on an interstate on ramp. If I let off the pedal, it stops. When exiting the interstate it is smooth, but if i gas it just a little the problem is there. I have replaced the drivers side hub/bearing thinking at first this was the problem. It was not. I do feel a little vibration under acceleration when going straight, but turn to the right and it feels like the car is going to shake apart. Going to the left does not seem to be problematic, jiust to the right. I am now thinking the cv shaft. Am I thinking in the right direction? Thanks.
Old Feb 10, 2018 | 01:57 PM
Hello and Welcome to the MCF! Cool that you have a Pace car edition, lucky!
I would jack it up to unload the suspension and tug around on a few things, pull on the tire back / forth, in and out.
A torque converter will also shudder when under load.
LINK:
5 Steps for Diagnosing Automatic Transmission Shudder
Old Feb 10, 2018 | 08:57 PM
cstar65's Avatar
Thanks for the reply. I am going to check as you suggested.
Old Feb 11, 2018 | 07:56 AM
Smile
Some one else had a similar thing a year or so back! I had suggested that it might be a broken belt in the tire.
They had thought they had checked that and ruled it out.
So the next thing you can do is put the car up on a lift or Jack stands and then fire it up, and put it in gear now you can see what the wheels are doing in motion.
This is pretty dangerous so you need to use extreme caution.
If I recall correctly they discovered it was a broken belt in the tire. I have had them with the tire all humped up in the tread.
Worth a check out for sure. Good luck!!
Old Feb 13, 2018 | 05:45 PM
cstar65's Avatar
Thanks for the suggestion. I will check it out for sure. Since it only happens under acceleration, I dont think its a tire, but will check it anyway.
Old Feb 17, 2018 | 01:29 PM
cstar65's Avatar
Well, apparently it was the cv shaft. Replaced it today and took for a test drive, and the problem is gone! Thanks for the suggestions. I also checked the cradle bolts while there, and they were tight. Hope this can help someone else.
