6th Gen ('00-'05): Heated seat not working
Old Sep 23, 2013 | 09:31 AM
Default Heated seat not working
So the other day it was chilly, I get into the car and turn my heated seat on and drive away. After a few mins im like wait a minute, why isn't this warm... So I've come to the conclusion its not working, passenger side still does. Aside from checking connections and fuse(haven't had a chance to yet) What other things should I check or do to get it fixed?
Old Sep 23, 2013 | 09:38 AM
owens91's Avatar
There was a sticky somewhere here that told how to basically take apart the seat and solder the broken wires inside. But that's why mines keep goin out is the fuse I out a 25amp instead of the 15 havent had a problem since
Old Sep 23, 2013 | 10:54 AM
TMoney's Avatar
I have the same problem you have Keane. My passenger one still works very good and gets got within like 30 seconds, but my driver one doesn't work. I have a feeling the heating element in mine is just simply burned out and it needs a new one
Old Sep 23, 2013 | 07:20 PM
Checked plugs and when checking the fuse diagram the drivers side heated seat is on the same fuse as the bcm, so that's obviously not blown. My guess is the heating elements are shot, not something I really want to get into.
Old Sep 23, 2013 | 07:49 PM
owens91's Avatar
That's weird I had a fuse jus for the seats. Well I hope u figure this out
Old Sep 23, 2013 | 07:52 PM
TMoney's Avatar
There is a guy near me that said he would replace the element for $150. Probably will end uo doing it because its so nice during the winter
Old Sep 27, 2013 | 04:29 PM
So the switch is still working fine and power is flowing into and out of the seat, but no heat. Any ideas?
Old Sep 28, 2013 | 01:09 PM
bump, any ideas?
Old Sep 28, 2013 | 01:51 PM
JC Colon's Avatar
Yeah I have the same problem. I guess it's cause the drivers side is used so much more than the passengers side. But the my passenger side seat is stuck. The sent moves up and down fine But the inner track will not move. I wanna take the seat out But I wanna wait till I have the underwent sub to put in so I can kill 2 birds with one wrench!
Old Sep 28, 2013 | 03:01 PM
How about a wiring diagram? would anyone be able to find one?
