Hearing water slushing around in my car
Old May 4, 2011 | 09:34 PM
jwjones's Avatar
Default Hearing water slushing around in my car
So recently I noticed that when I brake or accelerate from a stand still I can hear water slushing around from the passenger side of the car. It sounds like it is coming from the underside of the car somewhere but I have no idea where or how? Has anyone had this issue before? What can I do to fix this?
Old May 4, 2011 | 09:44 PM
do you have a sunroof?
Old May 4, 2011 | 09:55 PM
jwjones's Avatar
Yes sir
Old May 4, 2011 | 10:07 PM
Boxman420's Avatar
i bet its comming from your door. try shaking the door and listen for water. mine did that.. if thats the case then take a tooth pic to the drain hole on the bottom of the door.
Old May 4, 2011 | 10:13 PM
jwjones's Avatar
Okay awesome I'll try that tomorrow morning since I'm off :P. If thats not where its coming from where else could it be?
Old May 4, 2011 | 10:19 PM
Boxman420's Avatar
i wish you luck man! mine used to do that in heavy rain storms. it took 2 tries. just stick a tooth pic type of item up in the hole and knock it around a little. its probably clogged. Im not really sure.. i dont have a sunroof but my windshield leaked once but wasnt near enough water to cause "sloshing"
Old May 4, 2011 | 10:31 PM
there's a drain towards the bottom of the door jam i believe, that may need to be unclogged.
Old May 5, 2011 | 12:37 PM
jwjones's Avatar
Well I went out to the car this morning and sure enough there was water inside the door, alot of it too!
Here are some pictures from all the water that was let out:
When i first cleaned out the dirt:
The dirt:
Starting to fill up:
The aftermath:
Old May 5, 2011 | 12:58 PM
Boxman420's Avatar
yupp thats what mine did too. it may still have stuff up in there but mine hasnt done it since the second time i tried! glad it worked out for ya man!
Old Oct 25, 2011 | 12:37 PM
Mr.Monte's Avatar
did you just pull that rubber piece off?
