has any one removed there dash board
Old Aug 27, 2010 | 09:32 PM
monte07's Avatar
Default has any one removed there dash board
i need to fix my keyless entry and also need to fix the auto head light sensor on my monte has any one taken off there dash board and pad and how hard is it to take off and put on?
Old Aug 31, 2010 | 10:05 PM
Paul1965's Avatar
I haven't pulled mine yet, but this is supposed to be how:
Refer to Restraint System Service Precautions in Service Precautions".
1. Remove the instrument panel (I/P) cluster trim plate.
2. Remove the I/P right upper trim panel.
3. Remove the garnish moldings from the left and from the right windshield pillar.
4. Starting at the right side, carefully lift upwards on the defroster grill in order to release the retainers. Continue working to the left side until you have released all of the retainers.
5. Disconnect the daytime running lamps (DRL) sensor from the defroster grill.
6. Remove the defroster grill.
7. Remove the I/P upper trim pad screws.
8. Remove the remote keyless entry module.
9. Remove the I/P upper trim pad.
For re-installation, it gives some torque specs for the screws:
Tighten the horizontal screws to 2 N.m. (18 lb in).
Tighten the vertical screws to 10 N.m. (89 lb in).
Old Sep 3, 2010 | 07:44 PM
monte07's Avatar
thanks its a new in away and having troble with the keless entrey system is a head ake. i drove my mustang for 6 years and never had problems with it and having troubles with this one is a head ake.
monte07
Sep 22, 2011 08:15 AM
monte07
Jul 8, 2011 06:55 PM
monte07
Feb 15, 2011 07:38 AM
Montecarloguy07
Dec 9, 2009 12:51 PM
monte07
Mar 4, 2009 09:22 PM
