Gauge lights out?!?
Old Jun 5, 2007 | 01:00 PM
J_Bru_Ha_SS's Avatar
Default Gauge lights out?!?
So here is the deal, some of my gauge lights go out periodically. I simple thump on the dash usually brings them back to ilumination, it is extremely annoying though. Has anyone else had this problem, I was going to take the gauge cluster apart but thought twice about it after looking at it. It is mainly the tach that has the problem. I noticed it after I installed my new CD player, I think that is just coincodence and it is not because of the aftermarket CD player but I have been wrong before. Any help would be awesome.
Old Jun 5, 2007 | 04:40 PM
thatrealcreolenigg's Avatar
Default RE: Gauge lights out?!?
is it only ur gauge lights i have this problem with all my interior lights, and it happened after i installed my radio too. i found out my light switch shorted out really bad, and some of the other guys here light switch went bad also. they said they changed the switch out and it worked fine, i havent tried this but they say it worked
Old Jun 6, 2007 | 03:13 AM
Mrrench's Avatar
could be a ground problem
Old Jun 6, 2007 | 07:40 AM
it was the light switch on mine
Old Jun 6, 2007 | 12:00 PM
Which light switch are you guys talking about? I knew of one other light that went out, on the climate control. But now I noticed that the seat warmer switch light is also out. So this does have to do with me installing the aftermarket stereo then?
Old Jun 6, 2007 | 01:07 PM
Mrrench's Avatar
When you installed the aftermarket radio didyou cut the wire harness in the dash or did you get a harness to plug up to the one in car?
Old Jun 7, 2007 | 12:17 PM
I didn't cut any wires I used the wire harness from Peripheral Electronics harness#GMCO.
Old Jun 15, 2007 | 02:11 PM
im talking about the headlight switch they seem to go bad often from what i been reading here. when i installed my radio i used a hardness but when i was trying to find the problem i noticed that the dimmer wire from the headlight switch all the way to the radio was fried, and it kept shorting out my tailights. after i replaced it with one from the junkyard i noticed that the switch was fried on the same leg as mine but i tried it anyway didnt work. so i went out a bought a new and it works fine now
Old Jun 22, 2007 | 08:48 AM
Lman's Avatar
thatrealcreole****, I'm having the same problem. Where did you pick up a new at? How much? and do you happen to have the part #?
After looking more I found InTheIROC said:
AC Delco #: D1599F
GM #: 10406799
from this post: HERE
Also thought I would include a link to NAPA: Headlight Switch
If anyone finds it cheaper, please let us know.
Old Jun 25, 2007 | 01:58 AM
i got it from autozone it was 126.00 not sure the part number, but there r 2 kind one with fog light and one without
