Fuel tank pressure sensor / "evap sensor"
Old Aug 5, 2011 | 10:11 AM
98Z34's Avatar
Default Fuel tank pressure sensor / "evap sensor"
Are these the same thing and where is it located on a 2003 SS? I've got a P0440 code and the cap is good. I bought this part after hearing from a former GM mech that they go bad often and throw this code. I'm hoping it's not inside the fuel tank but reachable from from the outside. Any help on locating this thing?
Old Aug 5, 2011 | 10:28 AM
I would imagine it's most likely the EVAP Solenoid if the gas cap didn't fix it.
It's located behind your throttle body.
Old Aug 6, 2011 | 08:55 PM
98Z34's Avatar
Thanks for the reply, I haven't had a chance to look yet. Is this the solenoid of which you speak?
Click here --> Sensor I bought
Old Aug 6, 2011 | 09:06 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
My 2001 Monte Carlo SS 3.8L keep throwing DTC P0440 I - JustAnswer
I think that you are on the right track at least. ^^^Link
Old Aug 7, 2011 | 01:24 PM
98Z34's Avatar
Thanks for the help everyone. Well I found the bugger, right on top of the tank. I'm SO happy to have that access panel, I'd hate to have to drop the tank for any reason, especially for such a little thing. I'll wait a couple days just to see if the light resets itself, then probably have to do it manually to see if that was the problem.
86 luxury sport
Jun 6, 2011 02:41 AM
bitis316
Feb 11, 2011 12:22 PM
bitis316
Feb 11, 2011 07:39 AM
seal0716
Jan 1, 2010 10:21 PM
prodigynius
Sep 4, 2009 01:56 PM
