Fuel Pump Whine
Old Jul 10, 2013 | 09:52 PM
RedMonteCarloZ34's Avatar
Default Fuel Pump Whine
My '97 Z34 fuel pump is noisy. Been that way since I bought the car last month, so not sure if this is typical of these. The car has 78K miles. It makes a whining noise, louder than any other car I've owned.
How difficult (expensive) is the pump to replace by a repair shop?
Old Jul 11, 2013 | 12:03 AM
nitehawkjcb's Avatar
Check your fuel pressure, if it's good then you should be fine. My stock pump was loud, but it will likely run you a good 400 bucks in labor.
Old Jul 11, 2013 | 11:44 AM
cbetts's Avatar
Yep, mine is pretty loud as well. 134K miles on what I believe is the original pump (bought the car three years ago with 116K miles).
Old Jul 12, 2013 | 05:20 PM
Is the pump inside the tank?
Old Jul 13, 2013 | 07:45 PM
Yes the pump is inside the tank, so you need to drop the tank to get to it.
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
amberite
Jul 20, 2007 09:20 AM
PCWeber
Mar 11, 2007 10:58 PM
Monte Python
Jul 11, 2005 02:56 PM
