Fuel pump voltage loss
Old May 17, 2014 | 10:59 PM
KK525's Avatar
Default Fuel pump voltage loss
Hi I have an 01 monte ss, I have a voltage drop at the pump of 1-1.5 volts. I put a new pump and included wire harness with plug in, but still same problem. The car runs just not well. When you get on it the fuel pressure drops I am guessing because of the voltage drop, I have replaced a lot of sensors, and the cat. Anyone have any ideas on where to look for where I might be losing voltage. I have good readings under the hood, just drops by the time it gets to the plug on the pump.
Old May 18, 2014 | 09:56 AM
03SSLE's Avatar
The length and gauge of the wiring will create some resistance so you will see a slightly lower reading at the pump. A 1 - 1.5 drop would be considered normal. If the car is falling on it's face I'd check for a clogged fuel filter, the output of the fuel pressure regulator, and clogged injectors.
A vacuum leak could also create this scenario, but you should hear a sucking and/or whistling sound under hood.
Old May 18, 2014 | 12:26 PM
KK525's Avatar
I have put 2 new fuel filters on in the last 2 weeks, strained the gas that was in them thru a strainer and both were clean couldn't get a speck to come out of them. The fuel pressure at the regulator is 55 at an idle, when you hit the gas it drops instantly to 14 psi. I put a new regulator, mass air flow, checked the egr, changed both O2 sensors put a new cat on. I just put another new fuel pump in thinking I got a bad one, still the same. Checked for vacuum leaks and couldn't find any. Could it be a bad computer? I have dumped a lot of money in this car and still no changes. Thanks for the help.
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
blueSS
Dec 20, 2011 07:35 PM
Frosty LS1
Jul 17, 2009 08:24 PM
labnjab
Jul 5, 2009 07:23 AM
