Opinion Needed: Fuel problem 2000 SS
Old Mar 24, 2014 | 12:05 AM
GarySS's Avatar
Question Fuel problem 2000 SS
Hi guys new member here, have a 2000 Monte SS 3800,140K miles, went out to start it today to take my boy and his friend in town, after I started it, both the kids said they smelled gas real strong, (my sense of smell is about gone) so I shut it down, put it up on ramps, started it back up, looked over fuel system front to back, no leaks were spotted, they said it was from under the hood, no leaks spotted, it seems to run fine, I did have a starting issue a couple days before, it cranked over but wouldn't fire up, so I pedaled it and it started up, could FPR be bad and loading up the motor? which would make it smell rich? any suggestions?
Old Mar 24, 2014 | 12:41 AM
owens91's Avatar
Check the fuel pressure regulator. See if the hose connected to it leaks fuel. Or smells of fuel. If so tht needs to be replaced. Also check the fuel injectors to make sure they aren't leaking or anything
Slamjunk
Sep 29, 2014 03:56 PM
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
robknight13607
Mar 20, 2013 09:14 AM
MJClemm
Mar 18, 2013 07:10 PM
